    The front camera of my phone will not work.
    The camera app works, but only if I authorize it to use phone (like, the dialing authorization) which it never needed before.
    But in the camera app, I only have the rear-facing camera (which works) and no button to switch the two cameras.
    I JUST did a factory reset and the problem is still there. No apps have been installed.
    Would like to solve this ASAP so I can use banking app again (need camera to deposit money).
    06-05-2018 11:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone?
    06-06-2018 03:03 PM
  3. Rukbat's Avatar
    That sounds like a defective front camera module. If the camera doesn't respond to the app, the app doesn't show the "switch cameras" icon. Unfortunately, the only way to "fix" that is to have the module replaced. (It's not all that expensive on most phones - you pay mostly for the labor.)
    B. Diddy likes this.
    06-06-2018 04:07 PM
  1. Will I get updates in the US???
    By jeepentj in forum Huawei P20 & P20 Pro
    Last Post: 06-20-2018, 08:17 PM
  2. Mid range android phone recommendations
    By kenneth monk in forum General News & Discussion
    Last Post: 06-16-2018, 07:32 AM
  3. Sprint Galaxy S5 (Ting)... will it work in Europe or not?
    Last Post: 06-06-2018, 11:37 PM
  4. Whatd the difference between the to contacts icon on android phone
    Last Post: 06-06-2018, 04:41 AM
  5. New phones don't have per text notification sound! Is there an app for it?
    Last Post: 06-05-2018, 07:36 PM
