    Hey, I brought a new "Coolpad Note 3 Lite" Smart phone while i recently traveled to India, I took several pictures and i really, really need them. My phone doesn't display anything on the screen but only shows a red LED light it used to show while charging. I tried opening the phone and disconnecting the battery with the cable connected and the light was still on. It doesn't even show a charging symbol or anything on the screen and no key combinations work. Please help me as soon as you can..
    email: [removed by moderator]
    thanks in advance!
    06-06-2018 08:43 AM
  2. belodion's Avatar
    Screen failure perhaps?
    06-06-2018 09:43 AM
  3. Rukbat's Avatar
    Put the phone back together, do what you'd do to turn it on, give it a few minutes, then have someone call it. If it rings, or it doesn't ring, but they hear it ringing, either the screen or something else inside it is gone, but the phone is still working - it's connecting to the internet.
    If it doesn't ring on the caller's end at least, the phone needs a repair shop, but your pictures are most likely gone, unless they're at Google Photos.
    06-06-2018 04:11 PM
  1. Replies: 2
    Last Post: 07-13-2018, 05:14 AM
  2. Phone turns on after reaching a full charge
    Last Post: 06-06-2018, 04:25 PM
  3. Why do notifications disappear immediately after they appear in Oppo Phone
    Last Post: 06-06-2018, 03:30 PM
  4. Why can't i find my photos or videos anymore?
    By Twitchy Toby in forum Ask a Question
    Last Post: 06-06-2018, 03:29 PM
  5. Only 45 of my 110 contacts on my Galaxy A3 have sync'd with Gmail??
    Last Post: 06-06-2018, 09:30 AM
