    i have a t95n mini m8spro 2gb/8gb box i tried to update the firmware after alot fo searching for the correct firmware and it installed it ok i have a problem now when the box boots up it has a white message that says BoardTest not found then at the middle of the message it says insert u disk to install BoardTest i have tried the toothpick method with no success it wont go to the screen wit the options a need to put more firmware on it i can use my mouse but i cant get the white message to go away so i can do anything else
    06-09-2018 02:00 PM
  1. Why my Samsung Galaxy s 4 wont turn on?
    By plamen788 in forum Ask a Question
    Last Post: 06-10-2018, 03:07 PM
  2. On my S7 I used S Voice to make calls. I cannot find it on my S9. Where is it?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 06-10-2018, 01:53 PM
  3. Why can't a caller hear me on the Samsung galaxy s5
    Last Post: 06-09-2018, 09:09 PM
  4. How do i obtain the stock firmware for the cricket lg harmony(lgm257)
    Last Post: 06-09-2018, 01:29 PM
