    i have an htc 10 and i had the battery replaced yesterday. and now my phone wont connect to the network. in the network setting it says
    Operator name: unknown
    Signal strengthnothing)
    Mobile network type: Unknown
    Service state: Radio off
    Roaming: not roaming
    Ive tried doing research and many different things i dont want to have to do a factory reset. the company that replaced the battery opened the phone again today to check the connections and make sure everything was correct. Ive tried doing the ##update # and changing some settings like that nothing has worked ive tried contacting sprint and doing some of their suggestions nothing is working.
    just to give all the information. when they company replaced the battery they broke the screen the touch still works on the main part of the screen and the fingerprint sensor works but bringing the drop down menu does not and neither do the back or multitask buttons on the bottom will have a new screen in a few days and probably not related but i wanted to give all info that might help
    ive tried putting my sim card in my wifes phone it worked in hers but hers did not work in mine.
    sounds like this is a modem issue possibly. i have an htc U12+ on the way when its finally released but i need this phone working for the time being. any suggestions would be greatly appreciated. if you need any more information please let me know.
    06-10-2018 11:53 PM
  2. Laura Knotek's Avatar
    Welcome to Android Central.
    Would you be able to return the phone to the repair shop in order to have them do a proper repair?
    06-11-2018 12:34 AM
  3. ryan9102's Avatar
    I'm bringing it back in Thursday or Friday they are replacing the screen but they opened it up again today and said everything was connected properly and looked good inside. I don't know if their is something in particular they need to look at next time but I've read a few forums where phone have shutoff due to Low Battery and had the same issues I'm having right now
    06-11-2018 12:59 AM
  1. Is Lookout riskware apps anything to worry about?
    By LJ Sal in forum Ask a Question
    Last Post: 06-28-2018, 04:13 PM
  2. Can't sync anything to gmail account on note 8
    By Sol I in forum Samsung Galaxy Note 8
    Last Post: 06-12-2018, 07:39 AM
  3. CPU z thermal help
    By Aaron Yap1 in forum Ask a Question
    Last Post: 06-11-2018, 07:05 PM
  4. Upon restarting phone all chrome tabs have been closed.
    Last Post: 06-11-2018, 07:03 PM
  5. U8 smartwatch won't find lg phone
    Last Post: 06-11-2018, 06:58 PM
