1. Icy Bugs78's Avatar
    Hi my cellphone is Blu vivo 5 its charging even without charger and the battery stuck can you please help me???
    06-12-2018 07:53 AM
  2. Rukbat's Avatar
    There's something in the USB port - probably some dirt that conducts electricity. It's very flimsy in there so don't go sticking things into it, but try tapping a lower corner of the phone against a table (to loosen the dirt), then blowing it out. At the very worst, use a thin pointed wooden toothpick dipped into rubbing alcohol to gently clean both sides of the center piece, then blow it out again.
    If that doen't work, it has to go into a repair shop.
    06-12-2018 11:52 AM
