Have you checked the outlet you're plugging the chargers into? Does something else plugged into it work? (Maybe the circuit breaker tripped.)
If the outlet is good, the tablet has to go to a repair shop. The charging port could be broken, the charger itself (that's some circuitry inside the tablet - what you plug into the wall is just a power supply) could have a bad part or the battery could be completely dead.
