Prime Day deal: Save $200 on the Samsung Galaxy S21
  1. MachidoKH's Avatar
    I've just got my new Galaxy S9+ and for the first time i got it i didn't charge it 5h or 8h i just unplugged it when it's fully charged and my estimated battery was 17h+. But after i charged it 5h straight when it was already 70% now the estimated battery life dropped to only 12h... so is it the problem ? And is it because i overcharged the phone when it was already 70%? If so, what should i do to get my previous battery life ? Please kindly leave an answer thanks you
    06-18-2018 06:55 AM
  2. djrakowski's Avatar
    Take a look at the battery usage statistics to see if there's an app consuming excess power in the background:
    Settings->Device maintenance->Battery->Battery usage
    You didn't damage your battery by "overcharging." The phone and/or charger regulate current flow such that your battery won't be damaged in this scenario.
    MachidoKH likes this.
    06-18-2018 07:20 AM
  3. MachidoKH's Avatar
    Thanks you but why did my estimated battery life drop to 12h ? Or 12h is the average bettery life on S9+?
    06-18-2018 08:09 AM
  4. djrakowski's Avatar
    Well, mine isn't that low, so who knows? It took over a week for my battery stats to settle down and report a more accurate number, and I had one problematic app, but I turned off background activity and stats improved significantly.
    I also understand that the models with Exynos processors had shorter battery life than those with Qualcomm (I'm in the US, so mine has a Qualcomm).
    06-18-2018 08:41 AM
  5. MachidoKH's Avatar
    So how many hours is your estimated battery life after fully charged?
    06-18-2018 10:41 AM
  6. djrakowski's Avatar
    Mine's usually in the high-30's. Even now, with the battery gauge reading 87%, it's estimating a bit over 31 hours.
    06-18-2018 10:43 AM
  7. MachidoKH's Avatar
    Wow that's too long... what about daily use? How long can it go a day?
    06-18-2018 12:11 PM
  8. djrakowski's Avatar
    With moderate use (mostly phone calls, WhatsApp, texting, a few Hangouts, 1 hour or less of audio streaming and looking stuff up in Chrome) I easily get through a 15-hour day with at least 60% to spare.
    06-18-2018 12:42 PM
  9. djrakowski's Avatar
    06-18-2018 12:44 PM
  10. MachidoKH's Avatar
    This is mine after a bit of using... is that ok?
    06-18-2018 08:25 PM
  11. djrakowski's Avatar
    It seems quite low, but you might have more apps running in the background than I do. I seem to recall that Facebook was a real battery-killer, but I no longer use it so I can't tell whether that's still the case.
    Our screen-on time is similar, but mine was accumulated over a 7-hour span, while yours was used (it seems) for more than an hour straight.
    06-19-2018 05:53 AM
  12. Josef Wahlgren's Avatar
    Damn. .. I have a S9 and my battery went from 65% to 0% after listening to music at low volume for about 7 hours while sleeping with the wired in-ear phones you get with the phone and that's while the phone was in "sleep mode" it wasn't opened or turned on at all during those hours. Living in Europe I also have an Exynos
    06-20-2018 02:39 AM
  1. How is the Galaxy Tab S2 doing after a year or two?
    By christianttt in forum Samsung Galaxy Tab S2
    Last Post: 08-19-2018, 12:49 AM
  2. Why do i have always H+ indicator instead of 4g/4g+
    By stonebridgegr in forum Samsung Galaxy S8 & S8+
    Last Post: 06-19-2018, 01:49 PM
  3. Can't get to my setting on my phone
    Last Post: 06-18-2018, 05:51 AM
  4. Replies: 1
    Last Post: 06-18-2018, 05:47 AM
  5. Replies: 1
    Last Post: 06-18-2018, 04:57 AM
