    I have a Samsung Note 8 and a Samsung Gear Sport. Both are rated to IP68. However, I was wondering if sweat could damage them (from having my phone in my pocket/watch on my wrist) while working out or mowing the lawn. Does IP68 also cover reasonable amounts of sweat?
    06-27-2018 11:16 PM
  2. SpookDroid's Avatar
    Yes(ish). IP rating is for 'normal' water, and since sweat can be salty or oily or have other stuff in it (won't go into the anatomy lesson here), it might be a bit corrosive. BUT, that is usually taken care of by the materials used on these devices, especially sports-oriented ones, like your watch. Also, unless you have a problem (severe problem), your sweat wouldn't be as corrosive as, say, constant ocean water sprays, so you'd be fine. If you wanna be on the safe side, just rinse off your devices after a workout (with tap water, not more sweat) and you're good to go. Plus, that will also help (the watch, especially) from developing a funky odor after a few sessions.
    06-27-2018 11:26 PM
  1. Replies: 4
    Last Post: 07-10-2018, 11:39 AM
  2. Why does my music and videos keep pausing by itself on lg k20
    By unicorn wolf in forum Ask a Question
    Last Post: 07-05-2018, 10:37 PM
  3. Replies: 2
    Last Post: 06-28-2018, 12:03 PM
  4. Replies: 1
    Last Post: 06-27-2018, 10:44 PM
  5. Does Moto z2 have wave over sensor like my Turbo2?
    Last Post: 06-27-2018, 01:30 PM
