    I have a Galaxy S7 and this sound drives me nuts please help.
    07-10-2018 12:44 AM
  2. Rukbat's Avatar
    It's telling you that you should have charged it around 10% ago. You can turn the sound off, but even by running the battery down to 30% you're shortening its life. (Lithium batteries aren't deep-discharge batteries - the only reason we use them is that they're thin and light.) You should keep the phone between 40% and 80% for longest life. If you run it down until the phone shuts off, you can kill a new battery in a month.
    If you still insist on it, it's in Settings - where depends on the manufacturer.
    07-10-2018 01:14 PM
  1. 15% off code for Google Pixel 2
    By Ali Kaveh Aenehzodaee in forum Google Pixel & Pixel XL
    Last Post: 07-17-2018, 11:13 PM
  2. I'm having trouble with the display on my Motorola G play.
    Last Post: 07-10-2018, 01:40 PM
  3. Should I replace my battery?
    Last Post: 07-10-2018, 01:36 PM
  4. Why won't my Messenger picture update with my FaceBook profile picture?
    Last Post: 07-10-2018, 12:07 AM
