    I'm an air pistol shooter and want to analyze my body position from shot to shot. I'd like to connect my Kodak SP360 to an app on my phone and confirm the ideal position. This will then show as an outline on the screen that will go green when I'm inside it and record it as video so I can see the differences afterwards.
    It will be a mix of motion tracking software, Hudl and Xbox connect from my limited knowledge.
    Anyone know if this exists?
    Thanks
    07-10-2018 06:28 PM
  2. Rukbat's Avatar
    Do a search for developing android apps. And good luck. You can probably turn that one app you develop into a very-well-paying career. (But you'd have to develop the app yourself, as far as my searching shows - there's nothing out there like it yet.)
    07-11-2018 03:58 PM
  1. Replies: 1
    Last Post: 07-10-2018, 07:21 PM
  2. Delete t-mobile apps on unlocked phone
    Last Post: 07-10-2018, 07:20 PM
  3. how to link samsung note 4 calendar to hp laptop calendar
    Last Post: 07-10-2018, 07:16 PM
  4. My phone on incoming calls will ring (1) time before being transfered to voice
    Last Post: 07-10-2018, 04:14 PM
  5. how to get the android.proceser.acore has stopped fixed on a verizon LG G6
    Last Post: 07-10-2018, 03:53 PM
