    My cell keeps getting hot and the battery won’t hold a charge
    07-11-2018 02:51 PM
  2. belodion's Avatar
    A bad battery?
    07-11-2018 03:01 PM
  3. Billy Beckham's Avatar
    Reasons and solutions for not charging the phone:
    1. First of all, the mobile phone system is faulty, which causes problems in the battery power display. This kind of problem is the easiest to solve, you can directly shut down and restart, this is equivalent to data refresh, the general power display will return to normal.
    2. Second, the charger has failed. This kind of failure is the main reason why the mobile phone does not charge. Try another charger. If you can charge in and out, you can conclude that the charger is faulty.
    In the face of this problem, there is no way, only buy another charger.
    3. Poor contact between charger and mobile phone. This situation is also very common, because the mobile phone user careless, the result is not plugged in. The solution is simple, that is, changing the socket back and forth.
    07-12-2018 04:15 AM
  1. Tag connected first edition battery life
    By Johnny Housego in forum TAG Heuer Connected
    Last Post: 07-12-2018, 12:48 PM
  2. Is regular CPU thermal paste ok to use in a Phone?
    Last Post: 07-11-2018, 07:53 PM
  3. moto z2 call and message history not working for new calls and messages
    Last Post: 07-11-2018, 03:49 PM
  4. How do I unlock my phone?
    Last Post: 07-11-2018, 03:03 PM
  5. Why my screen turns yellow?
    Last Post: 07-11-2018, 03:02 PM
