    Every time I try to connect to a WiFi network on my new Blu Android phone I keep getting an " authentication problem" response, how do I correct this?
    07-12-2018 04:28 AM
  2. djrakowski's Avatar
    Welcome to Android Central!
    It sounds like you're trying to connect to a password-protected WiFi hotspot. Have you successfully connected to it in the past? If so, then you should know (or have access to someone else who knows) the password.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    07-12-2018 05:35 AM
  1. Cannot connect to public wifi
    By lowbrew in forum Ask a Question
    Last Post: 07-12-2018, 12:28 PM
  2. Speaker Phone during calls
    Last Post: 07-12-2018, 12:26 PM
  3. Mobile data not working when away from WiFi
    Last Post: 07-12-2018, 06:51 AM
