    I just got my Honor 7x, I opened the phone did the usual stuff and then started USING it, it auto updated some apps, an then I deleted some of the apps I didn't need, and downloaded the apps i'm gonna use, after that the phone was on 43% (It comes with 50% already on it) i then began charging it with the included cable and after more than an hour the phone is only on 80% Is this normal or is it bad? and if so how can I fix it?
    07-14-2018 11:30 PM
  2. Rukbat's Avatar
    That's about normal. If you want it to charge faster, turn the phone off when you're charging it. But taking an hour for 40% to 80% isn't bad. (For longest battery life, charge it when it drops to 40%, stop charging when it gets to 80%.)
    07-15-2018 01:59 PM
  1. Where's the Swype keyboard on the Moto G5?
    Last Post: 02-15-2019, 12:42 PM
  2. My V30 won't use the third party messaging app
    By Android Central Question in forum LG V30
    Last Post: 07-18-2018, 12:17 AM
  3. Can only hear caller over speakerphone.
    By GeoGoGo in forum Samsung Galaxy Note 8
    Last Post: 07-15-2018, 10:15 PM
  4. Can't get rid of <unknown> artist folder on Pi Music Player for Android
    Last Post: 07-15-2018, 10:10 PM
  5. Replies: 1
    Last Post: 07-15-2018, 01:51 PM
