    I have a ZTE Blade Spark, and for the first few months of having it, it worked well. Now whenever I'm in a call the other person cannot hear me. The mic works fine when I'm using text to speech, or using voice commands for Google. When I try to record a video on Snapchat the audio starts out scratchy but gets better. This happened to another ZTE phone I had previously as well.
    07-16-2018 06:40 PM
  2. Rukbat's Avatar
    It could be a bad mic (the mic used for phone calls isn't the same mic as the one used for other things), it could be a bad connection, it could be something bad on the motherboard. In any case, it has to go to a repair shop, there are no buttons you can press to fix it (except using the speakerphone).
    07-17-2018 01:36 PM
  1. Replies: 27
    Last Post: 07-20-2018, 04:19 PM
  2. How do I turn off the screen lighting up every time I get a notification on Galaxy 9+?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 07-17-2018, 02:20 PM
  3. Phone charging when switched off but not when switched on?
    Last Post: 07-17-2018, 01:43 PM
  4. when the phone ring i can't ansewr the phone
    Last Post: 07-16-2018, 05:01 PM
  5. Replies: 1
    Last Post: 07-16-2018, 04:52 PM
