Welcome to Android Central!
Where are you seeing the "Verizon Wireless" branding? Is it at the top of the display, all the time? Is it in a settings menu?
Are you a Verizon subscriber? Even if you're not, the K20V is a Verizon phone, with Verizon firmware, so I doubt you'll be able to make any modifications that result in removing Verizon's branding from the phone (without gaining root access and flashing a custom ROM, which I almost never recommend to anyone but the most technically-adept of smartphone owners, and even then, I don't know whether it's possible to root the K20V).
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See
this link for instructions on how to join Android Central.
