    in the call forwarding option following options are not working:
    Forward Always
    Forward when not reachable.
    07-28-2018 07:08 PM
  2. Rukbat's Avatar
    That's up to your carrier - some have the function, some don't. Call them (611 usually works if you're in the US) and ask. If it's for "not reachable", you probably want that permanent, so they can set it for you. If it's for "always", you probably want access to that (like "forward all my calls until this meeting is over"), so see what they suggest.
    07-29-2018 03:46 PM
  1. Replies: 5
    Last Post: 07-30-2018, 02:36 PM
  2. I can't open Google assistant via voice
    By Yazy Lee in forum LG G7 ThinQ
    Last Post: 07-29-2018, 02:53 AM
  3. What the hell is clone_children cgroup and sane behavior?
    Last Post: 07-28-2018, 05:44 PM
  4. Hauwei p20 pro Camera types are misaligned and difficult to see
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 07-28-2018, 02:32 PM
  5. Hauwei p20 pro Camera types are misaligned and difficult to see
