    Hello all, i got weird battery drain after the latest update- from 100% charged i went to bed and when i woke up after 9 hs it was 86% and it keep draining quite fast. Anyone else got this problem? I checked the apps but they all were 0% usage
    07-30-2018 02:02 AM
  2. John Smith227's Avatar
    My problem is that I have a HUGE battery drain going on right now. SoI do prefer these steps :-
    To close all running apps, select the Recent apps
    buttonSelect CLOSE ALL
    Slide down the top menu
    Slide down the top menu again
    Turn off Wi-Fi and Bluetooth
    Turn off Location
    Select the v button
    Turn on Auto brightness and select DONE
    Select Power saving
    Select APPLY
    07-30-2018 03:15 AM
  3. nerzuhl's Avatar
    Yes but the question was does anyone notice the huge battery drain after latest update
    I sow a similar problem for J7 here too
    07-30-2018 10:04 AM
  1. AT&T Galaxy S8 Galaxy S8 crashed and now will not turn on with a constant ticking sound coming from the inside.
    By Connor Hall in forum Samsung Galaxy S8 & S8+
    Last Post: 07-30-2018, 04:40 PM
  2. Why is my battery draining so fast on Moto z2
    Last Post: 07-30-2018, 04:22 PM
  3. why wont my computer recoginze my samsung galaxy note 4
    Last Post: 07-30-2018, 04:19 PM
  4. Help me shut down my Galaxy S7 without a code
    Last Post: 07-30-2018, 04:08 AM
  5. Newdery battery case mini review
    By lldsandsll in forum LG G7 ThinQ
    Last Post: 07-30-2018, 12:42 AM
