    Is it possible to power on an lg android phone model lgl33l without using a battery only using an usb cable.
    Like is there a way to do this without having to either A get a new battery or B brake it all down and try somehow to touch wires to the positive and negative tabs on the motherboard itself.
    08-03-2018 11:14 AM
  2. SpookDroid's Avatar
    Most phones don't allow this as the Battery completes the circuit. If connecting the charger to the phone still yields no power, and you're absolutely certain the issue is the battery and not the charging circuit, then the only way to do this is to bypass (hardwire) the battery terminals AND protection circuitry.
    08-03-2018 11:26 AM
  1. My J-3 phone after restarting says low better. why?
    Last Post: 08-03-2018, 04:58 PM
  2. how to turn off message blocking on my lg phone
    Last Post: 08-03-2018, 04:31 PM
  3. can't transfer music from pc to phone
    Last Post: 08-03-2018, 03:37 PM
  4. How do I do a simple root on a J3 Luna pro without computer?
    Last Post: 08-03-2018, 03:15 PM
  5. How do I get to my clipboard on my LG G5
    Last Post: 08-03-2018, 11:27 AM
