Save big + get 3 months free! Sign up for ExpressVPN today
  1. Prestosuey's Avatar
    I'm on a lg g5 that I got from Verizon I thought it was just a battery wear problem but when I got a new one it's almost as bad
    08-11-2018 07:06 PM
  2. belodion's Avatar
    Welcome.
    Is your signal poor?
    08-12-2018 05:59 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you actually noticing poor battery life, or are you only noticing the Phone Idle battery usage in that menu?
    08-12-2018 12:31 PM
  4. Rukbat's Avatar
    A lot of Phone Idle battery usage means that you chose the wrong carrier - they have a weak signal where you are. Your best bet is to find a carrier with a stronger signal and go with them. (And ask Verizon to let you out of your contract since they can't provide usable signal where you are.)
    Laura Knotek likes this.
    08-12-2018 12:40 PM
  5. B. Diddy's Avatar
    Do you know if Phone Idle is the same as Cell Standby? I think I've seen both of them listed separately on the same Battery stats, so I thought they were different, but I could be misremembering.
    08-12-2018 04:30 PM
  6. ManiacJoe's Avatar
    If your phone supports it, and your carrier allows it, "wifi calling" helps a lot with bad signals at your house, assuming you have a high-speed internet connection available and a wifi router.
    08-12-2018 04:35 PM
  7. Rukbat's Avatar
    I think that Phone Idle and Cell Standby refer to the same thing, but I wouldn't swear to it without going through the source code.
    ManiacJoe likes this.
    08-12-2018 04:43 PM
  8. Prestosuey's Avatar
    No cell standby is low if none at all
    08-13-2018 09:06 AM
  9. Prestosuey's Avatar
    I have Verizon and I'm in highly populated area of illinois
    08-13-2018 09:07 AM
  10. Prestosuey's Avatar
    Welcome.
    No I usually get 3 to full bar 4g
    08-13-2018 09:09 AM
  11. Prestosuey's Avatar
    Also just checked I do have cell standby so phone idle and that arent the same in the battery usage page
    08-13-2018 09:15 AM
  12. Prestosuey's Avatar
    I'm noticing poor battery life and the phone idle usage being the main drainage in the menu
    08-13-2018 09:25 AM
  13. Rukbat's Avatar
    Use something like LTE Discovery and let us know what the signal strengths are.
    08-13-2018 11:39 AM
  14. Prestosuey's Avatar
    Attached Thumbnails It seems that my phone idle is taking up most of my battery besides screen but thats expected-screenshot_2018-08-13-21-38-00.jpg
    08-13-2018 09:41 PM
  15. belodion's Avatar
    This may be a device issue, since other users have noticed the same thing.
    08-14-2018 07:16 AM
  16. B. Diddy's Avatar
    Normally, I'd suggest trying a cache partition wipe, but LG doesn't let its users access the Recovery Menu. See if the problem happens in Safe Mode as well: https://support.t-mobile.com/docs/DOC-30620. If it does, then you could try using Verizon's Software Repair Assistant to reinstall the firmware.
    08-14-2018 10:44 PM
  1. is the op6 worth it?
    By AKFL3TCH3R in forum OnePlus 6 & 6T
    Last Post: 08-19-2018, 07:10 PM
  2. Screen is cracked and doesn't turn on, phone works...what do i buy?
    Last Post: 08-12-2018, 01:54 PM
  3. com.sec.epdg, on my screen, can´t do anything, HELP !!!!!
    Last Post: 08-11-2018, 09:06 PM
  4. Being charged for phone while waiting for replacement!
    Last Post: 08-11-2018, 08:36 PM
  5. can't use/reset my smartphone
    Last Post: 08-11-2018, 06:28 PM
