I have a W95 box and it was working fine. I unplugged it to move it and now it won't work. No red or blue light comes on. Also have 1 mxq pro and 1 mxq same problem. Any suggestions is this fixable
Move the box back and plug it into the outlet it used to be plugged into. (If it works there, but not in the new location, the outlet may be bad. Some things connect, some don't.)
Make sure the wire isn't frayed, chewed on, etc. Moving it may have stopped it from working.
