    I have owned a Nextbook Ares 8A with Android 6.0.1 for nearly three months, but the other night, I plugged it in to charge, and something strange happened. I was using the tablet perfectly fine, then I powered it off because my battery was at 20%. When I connected it to my charger, the red light on top turned on, but the charging screen did not show. I unplugged it and attempted to turn it back on, but nothing happens at all other than my CPU severely and instantly overheating. What do I do, and is there a way to fix this? I have retried charging, rebooting, and resetting the battery several times with no luck.
    08-18-2018 12:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery may have failed -- the heating you feel is probably the battery, and not the CPU. Contact the manufacturer, if it's still under warranty.
    08-18-2018 01:12 PM
  1. $5 Off on UAG Site With Email Retention Offer
    By Echoes in forum Samsung Galaxy Note 9
    Last Post: 08-19-2018, 01:28 PM
  2. Why is my phone only working on cdma and not cdma/lte?
    Last Post: 08-18-2018, 07:54 AM
  3. Replies: 0
    Last Post: 08-18-2018, 12:04 AM
  4. Why do i have an unread notification in me messaging that show the number 1
    Last Post: 08-17-2018, 11:31 PM
  5. My System keeps defaulting back to system messenger
    Last Post: 08-17-2018, 10:15 PM
