    I have j5 prime and the battey is fast discharging
    08-21-2018 05:57 PM
  2. belodion's Avatar
    If that did not happen in the past, perhaps you need a new battery?
    08-21-2018 06:33 PM
  3. Moumni's Avatar
    But i buy it one month agi
    08-21-2018 07:02 PM
  4. belodion's Avatar
    Okay. Welcome as a new member.
    Screen is of course usually the highest user of charge.
    Charge to 100%, use the phone normally until at about 40%, then post a screenshot of your battery usage stats. We'll then try to diagnose.
    08-22-2018 06:46 AM
  5. Moumni's Avatar
    https://ibb.co/fNraLz this is the screenshot
    08-22-2018 11:22 AM
  6. belodion's Avatar
    I see nothing abnormal there, assuming that you had a reasonably good screen-on time.
    Also, see this:
    https://r.tapatalk.com/shareLink?sha...4&share_type=t
    08-22-2018 01:13 PM
  1. How long to update my software on s9 android phone when its downloading
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 08-22-2018, 08:50 AM
  2. lock out of my phone
    Last Post: 08-21-2018, 06:41 PM
  3. My pictures & icons is looking like negative prints. How do you change it back?
    Last Post: 08-21-2018, 06:35 PM
  4. Replies: 0
    Last Post: 08-21-2018, 04:54 PM
  5. Can't sign even though it's in my devices
    Last Post: 08-21-2018, 04:49 PM
