    my mobile infinix X572 not charging and not power on plezz help me?
    08-23-2018 10:12 PM
  2. belodion's Avatar
    Assuming that you're using a good wall socket and that your charger fuse is good, it could be a bad charger, bad USB lead, bad USB port on the phone, something else bad inside the phone, or a bad battery.
    Try a lengthy undisturbed charge. If no go, consider the things I've mentioned.
    https://forums.androidcentral.com/sh...d.php?t=409154
    08-24-2018 06:43 AM
  3. Rukbat's Avatar
    Plug in the charger and leave it charging for at least 4 hours before trying to turn it on. If the battery is totally dead, it could take a few hours to start charging. (It's called pre-charge.) And if you've regularly been using it until it turns off, you could have killed the battery, Never let it get below 40%. If it gets down to 39% and you can't charge it, turn it off. (Never charge above 80% for longest life.)
    Lithium batteries are actually not the right kind of battery to use for cellphones - but they're light (lithium is the lightest metal at normal temperatures) and they can be made thin. But they can't take deep-discharge. The best battery would be a little car battery, with gelled electrolyte - a gel-cell battery. But it would weigh more than the phone and be as large as the phone. We all want thin and light (I don't, but most people do), so we get lithium batteries. And no instructions on how to care for them, because replacing batteries is a high profit business.
    08-24-2018 02:58 PM
  1. Replies: 1
    Last Post: 08-24-2018, 04:43 PM
  2. Why am I getting notification a sound from facebook posts?
    Last Post: 08-24-2018, 01:55 PM
  3. My Samsung Galaxy J12016 has no service
    Last Post: 08-24-2018, 06:45 AM
  4. get "handle is invalid"
    Last Post: 08-24-2018, 02:07 AM
  5. why can't I open my downloaded files?
    Last Post: 08-24-2018, 02:05 AM
