    I went through the process *#0011# to wifi and the report below was given the information below
    WiFi information
    State: DISCONNECTED
    SSID: <unknown ssid>
    AP MAC: null
    BSS CH: N/A
    WSEC: N/A
    Hi/Op: N/A
    RSSI: N/A
    Modulation: N/A
    CR: N/A
    PER: N/A
    TX: N/A
    Link Speed: N/A
    NETWORK: N/A
    IP:0.0.0.0
    MAC: EC:1F:72:3D6:FB
    Passpoint: Supported
    P2P Group mode: null
    P2P Freq: null
    P2P Peers : null
    P2P IP Addr:null
    PING TEST 0.0.0.0
    IP Ping Result:
    Can you help me resolve this problem
    Asaduzzaman Tutul likes this.
    08-29-2018 12:47 PM
  2. Rukbat's Avatar
    Basically, all that information tells us is that the Wifi isn't connected to any Wifi signal. It doesn't tell us why. Have you turned it on, then tried to connect to a Wifi router you know the password to (or one that doesn't require a password - like Walmart)?
    And please create an account here so you can post your answers under my questions.
    08-30-2018 01:35 PM
  1. Do I need a new charging port for my Samsung Galaxy S6?
    Last Post: 08-29-2018, 10:41 PM
  2. Could you remove that emoji and return my phone back to the regular face
    Last Post: 08-29-2018, 03:51 PM
  3. Mysterious " My Favorite Images" tab appears when d/l a photo
    By 25544 Norad in forum Samsung Galaxy Tab4 10.1
    Last Post: 08-29-2018, 12:26 PM
  4. Android Sub-menu on icon long press
    By rojaac in forum AT&T Galaxy S III
    Last Post: 08-29-2018, 12:04 PM
  5. Samsung pay framework battery drain
    By jmcook79 in forum Ask a Question
    Last Post: 08-29-2018, 11:39 AM
