    I am browsing on my J5 prime(battery 2400mah) for about an hour and it drained from 100-90%.I usually follow the 40-80% rule, but it gave me a battery memory problem so to calibrate it i charge it from 0-100%.Is this percentage of battery draining is fine? And what measures i can do for the battery problem.
    08-31-2018 08:56 AM
  2. Kodak2's Avatar
    10% for an hour of browsing depending on what you are browsing is not far out.
    08-31-2018 09:00 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! There are a number of factors. Poor cell signal is a common factor -- how was the cell signal strength when you were browsing? (This can still matter even if you had wi-fi on at the time.)
    08-31-2018 02:56 PM
  1. Can't access my Viber on my Samsung Tab anymore...why not?
    Last Post: 10-29-2019, 08:22 AM
  2. HTC 10 can't move photos FROM SD card to internal storage
    Last Post: 09-05-2018, 12:12 AM
  3. Is "removing" the same as "erasing" when wanting to remove a device from google?
    Last Post: 08-31-2018, 05:26 PM
  4. where is space key on galaxy j3 luna pro ?
    Last Post: 08-31-2018, 11:51 AM
  5. How did my Samsung phone go back to factory reset.
    Last Post: 08-31-2018, 11:50 AM
