Originally Posted by
B. Diddy Strange. Could it be that the positive and negative terminals were switched?
Okay, I just had a chance to test it, and it seems like the terminals are in the same direction; both give positive voltages in the same orientation. Odly enough, when I connect the phone to a charger with no battery attached, the "battery charging" symbol flashes, but when I actually snap the battery in, it's completely unresponsive again.
Another thing I noticed, the batteries give two different voltages; my OWM battery is at ~4V and the HETP one is at ~3.85. My OEM battery says the "Charge voltage" is 4.4 but the "nominal voltage" is 3.85, same as the HETP. Will this matter at all?
