    I have a Pixel 2 running Android Pie. Today I noticed that the battery indicator had turned red while the charge was at 34%. I rebooted it, no difference. So I plugged it in to charge for a bit. The charge is now at 64%. Whenever I unplug it from the charger, the indicator turns red again. Anyone familiar with this issue?
    09-13-2018 01:38 PM
  2. pwilliamson23's Avatar
    I've got exactly the same situation, only noticed it for the first time this evening.
    09-13-2018 02:11 PM
  3. arpdkvcs's Avatar
    Same here...
    09-13-2018 02:12 PM
  4. pwilliamson23's Avatar
    I've just noticed the battery saver is on, never switched it on before, my battery was at 47%. Switching it off solved the issue.
    CitySky likes this.
    09-13-2018 02:15 PM
  5. hallux's Avatar
    Just picked up my phone and noticed the same thing. Pixel 2 XL
    Edit to add: Check your battery saver settings. I found this - https://productforums.google.com/for...hone-by-google and after reading it went to check mine and found that battery saver somehow got set to turn on at 99%. I just flat turned it off as I never let the battery get to a point where it's an issue.
    CitySky likes this.
    09-13-2018 02:20 PM
  6. arpdkvcs's Avatar
    Also figured out that it was the battery saver, which was set to turn on automatically at 99%. The strange thing is that I have never set anything at this setting.
    09-13-2018 02:25 PM
  7. CitySky's Avatar
    Hi, I've had the exact same problem this week and, like other users, was able to solve it by fiddling with my battery saver settings.
    I will note that deactivating battery saver from the pull-down menu did not work; I had to go to Settings. Also the battery saver was set at 15% where I had left it ( and the icon was still on, and voice commands were deactivated, at a charge level of >70%).
    I readjusted battery saver settings and turned the feature off. Sure enough, it works fine now, and I can go back to talking to my phone again.
    01-18-2019 07:55 AM
  1. How do you replace the battery on the LG Sport?
    By Android Central Question in forum LG Watch Sport
    Last Post: 12-22-2018, 11:15 PM
  2. Pixel 2 Camera Question
    By dennis246 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-17-2018, 11:56 AM
  3. Pixel 2 camera getting better with time?
    By Jack Murphy2 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-13-2018, 11:10 PM
  4. How do you replace the battery on the LG Sport?
    Last Post: 09-13-2018, 08:05 AM
  5. My Huawei P20 Battery is draining so fast
    Last Post: 09-13-2018, 06:16 AM
