1. Patrick1016's Avatar
    After doing a Hard reset on tablet now it is stuck on wifi connection page saying cant connect with google servers try again later.
    09-13-2018 08:19 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you try it on another wi-fi network (preferably an open public network, like at your local library)?
    09-13-2018 09:02 PM
  3. Rukbat's Avatar
    It's not supposed to be connecting to Google servers on the wifi connection page. Make sure you're reading what it actually says, and get back to us. (If it says "can't connect" when trying to connect to your own router, make sure you entered the password correctly.
    09-14-2018 12:58 PM
  4. B. Diddy's Avatar
    I'm guessing the OP is talking about the screen that asks for your Google account. It might also be an issue related to Factory Reset Protection, if the previous Google account wasn't removed prior to the factory reset.
    09-15-2018 12:34 PM
  1. Cannot find where Amazon Music downloads to
    By THEPRFCT10 in forum Samsung Galaxy S9 & S9+
    Last Post: 09-22-2018, 03:35 PM
  2. Replies: 2
    Last Post: 09-14-2018, 03:46 PM
  3. Can i set data sim(#2) to be primary data reciever for dual sim Oneplus 6?
    Last Post: 09-14-2018, 02:09 PM
  4. How do I downgrade from 8.0 to 7.0 with a Samsung Galaxy S7?
    Last Post: 09-14-2018, 01:01 PM
