    I bought Samsung s8 few days back and I was trying to change my existing calendar event color and I tried everything but no luck.I can change or select my new event color but not for existing.
    09-14-2018 10:23 AM
  2. SpookDroid's Avatar
    Where are the events stored/coming from? If the calendar they're saved to doesn't allow edits (or doesn't support custom colors) you won't be able to change them. If you create an event into a calendar that supports it (like your Google account, for instance), then when you open the event details you should see the color next to the event title. Tapping that would prompt you to change the color if you want.
    09-14-2018 10:47 AM
  1. Heeelpp quick with restore
    Last Post: 09-14-2018, 02:39 PM
  2. Replies: 1
    Last Post: 09-14-2018, 02:17 PM
  3. Why I can't install some apps?
    Last Post: 09-14-2018, 10:18 AM
  4. Home button takes me to last app page, not home, how do i correct this?
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 09-14-2018, 07:53 AM
  5. Home button takes me to last app page, not home, how do i correct this?
