    I have a LGL58VL and I want to turn off my LED light when I receive a text. I will start bow hunting in Oct. and I can not have that flashing. Help!! I've looked everywhere on my phone.
    09-17-2018 10:18 AM
  2. SpookDroid's Avatar
    Unless the app you're using supports fine-grain control of notifications (LED, Sound, Vibration), you can only turn have it on or off along with sound/vibration. If you use a different app that supports this level of control (like Textra), then you can set the LED to 'Off'. You can also try notification customizer apps like Lightflow.
    09-17-2018 11:20 AM
  1. how to delete uninvited advertisement from phone?
    Last Post: 09-17-2018, 11:25 AM
  2. Replies: 1
    Last Post: 09-17-2018, 11:23 AM
  3. US Unlocked GS9 Update to ARH7
    By daswooski in forum Samsung Galaxy S9 & S9+
    Last Post: 09-17-2018, 10:15 AM
  4. How to change Quick Memo startup screen?
    By lotus1922 in forum Android 5.0 Lollipop
    Last Post: 09-17-2018, 10:02 AM
  5. Speech output, want to turn off
    Last Post: 09-17-2018, 09:49 AM
