    My phone battery will say it is on 100% and then when I unplug it from the charger it dies at an alarming rate and then I can sometimes power it back on and it will be somewhere around 45% charged but shutdown again and again.it basically only works when it is plugged into the wall charger unit with a USB cable like normal.what is the problem?do I have a virus?are there dead energy cells in my battery that could've came with the unit in the box brand new?are there any other explanations?is it possible for a remote access application stored and running on another device to power down my phone?
    10-01-2018 03:56 PM
  2. belodion's Avatar
    It sounds to me like a bad battery, but it may need repairer diagnosis to be sure.
    10-01-2018 04:49 PM
  3. Rukbat's Avatar
    Definitely sounds like a bad battery, probably from letting it discharge too far constantly. It could also be a dendrite, but from the description it sounds like it's been drained too far for too long.
    10-01-2018 05:05 PM
  1. How to remove System Icons from App pages Android Emui8
    By FAice in forum General Help and How To
    Last Post: 10-01-2018, 06:13 PM
  2. Bluetooth and text msgs
    Last Post: 10-01-2018, 03:27 PM
  3. My phone asks Allan are you still sitting on the loo
    Last Post: 10-01-2018, 03:25 PM
  4. Why does the sound crackle when I use the vidoe zoom on my Samsung J3 2017
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 10-01-2018, 03:10 PM
  5. Why does the sound crackle when I use the vidoe zoom on my Samsung J3 2017
