    I have it attached to my PC for sound. The musical dripping noise is about once every second. How do I stop it? No programs are running.
    10-02-2018 11:36 AM
  2. Rukbat's Avatar
    It's most likely something wrong in the device (unless you have Bluetooth earphones you can test it with, and you get the same problem with them - then it would be the phone). I'd contact the Crasher Mini manufacturer.
    10-02-2018 02:36 PM
  1. Bluetooth drops when wifi switches to data
    Last Post: 10-02-2018, 09:07 PM
  2. Why is everything doubled ony phone?
    Last Post: 10-02-2018, 03:31 PM
  3. Is this the reason my phone does not Update - Sam C9 Pro SM-C9000
    Last Post: 10-02-2018, 01:45 PM
  4. Why is my VPN causing my I have Moto G4mobile to reboot?
    By Petermark in forum Moto G (2015)
    Last Post: 10-02-2018, 12:38 PM
  5. Personalized notification sounds for text messages
    Last Post: 10-02-2018, 11:54 AM
