A
Android Central Question
Hello, I just acquired a Huawei P20 pro from an ASUS zenfone 2 (it got stolen) and there is something bothering me : when I'm on the lock screen, I see notifications normally but I can drag it down to have it show the notification expanded (like you can do when you have the phone unlocked and you are looking at the notifications, dragging one with the finger will expand, showing the full message for example), is there a way to enable it on this phone? I couldn't find a setting for this
thank you
thank you
