    10/4/18 Got a brand new Note 9 on 9/24/18. Battery Life was about 16 hours until I had an update on 9/27/18 . Now battery will not last more than 7 or 8 hours. I followed Samsung's 10 steps except a total factory reset. I got about 10 hours of light use. I checked each app battery use. Bixby Voice Wake up used 19% and is was not turned on. Settings used 19%. AT&T Find my Mobil used 19 % and Device maintenance used 19%. All my other apps used the remainder of the battery which was then at 11% . I can't delete these items. The phone store will give me a new phone but this appears to be a software problem from Samsung or AT&T.
    Searching for answers.
    10-04-2018 10:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you already tried wiping the cache partition? https://support.t-mobile.com/docs/DOC-38222
    10-05-2018 01:56 AM
  1. Will best buy so allow pre-orders right after the event?
    By KillerQ in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 10-09-2018, 05:26 AM
  2. Playing Galaxy S4 voice recordings on Note 9
    Last Post: 10-05-2018, 12:50 PM
  3. My infinix note for not coming on for days
    Last Post: 10-05-2018, 02:08 AM
  4. I do not have the "enable wifi" option on my LG G3 T-Mobile phone
    Last Post: 10-05-2018, 02:07 AM
  5. My tap to speak is stuck and I want it off now
    Last Post: 10-05-2018, 02:05 AM
