    I am looking for a stronger battery, Treasure battery is 2125mAh.
    10-05-2018 05:11 AM
  2. belodion's Avatar
    G3 battery is 3000mAh.
    10-05-2018 05:15 AM
  3. Mooncatt's Avatar
    Batteries are usually sized for a specific phone, so I'd say no. Not to mention any G3 battery is going to be so old that it'll likely have lost much of its capacity anyway.
    If you are needling a larger capacity battery, this is about all I could find.
    https://www.amazon.com/Treasure-Stra...cUvbUpU6358223
    It's not a brand I recognize, butI do see a couple of red flags with it.
    1. Extended batteries are generally thicker, and come with a replacement back for the phone to hold it. This battery claims a higher capacity with the same physical size. That means the internals either are not as robust in order to hold more surface area for ion transfer and will wear out quicker, or its just false advertising.
    2. They claim to ship it with "little to no power." One of the quickest ways to kill a Li-ion battery is to drain it and leave it that way. These batteries like a happy medium, and reputable manufacturers will ship it with what's known as a storage charge. That's usually 50-75%, which protects the battery from the natural self-discharge while it sits on the warehouse shelf. If this company ships with little to no charge, it could very well be toast before it even leaves the warehouse.
    Definitely buyer beware.
    10-05-2018 06:55 AM
  1. Replies: 5
    Last Post: 10-05-2018, 01:55 PM
  2. Why is the new update draining battery so much quicker?
    Last Post: 10-05-2018, 05:12 AM
  3. Why is my phone not fast charging?
    Last Post: 10-05-2018, 04:41 AM
  4. How do I disable the vibration during an incoming call,
    By Aadan Cabdi in forum Ask a Question
    Last Post: 10-05-2018, 02:40 AM
  5. Why doesnt my LG G6 end call button work?
    Last Post: 10-05-2018, 02:30 AM
