Are you sure there's no little piece of plastic covering the front camera lens? You're supposed to take that off before you start using the phone.
Check the white balance in the camera app. If it's set to fluorescent and you're using incandescent lighting, you're get a yellowish-reddish cast over everything.
If it's neither of those, your front camera module could be bad.
