    I will connect it and then it will disconnect and when i go onto wifi settings it will say disabled. I tried turning off and back on my phone also i've tried restarting my phone. It won't stay on.
    10-21-2018 02:27 PM
  2. B. Diddy's Avatar
    Did you also post this? https://forums.androidcentral.com/as...home-wifi.html. In any case, please join the discussion in that thread. You'll have to register on this forum first. https://forums.androidcentral.com/as...community.html
    10-21-2018 02:58 PM
  3. B. Diddy's Avatar
    Also, if you're on Cricket, try turning off Cricket Wi-fi Manager: https://forums.androidcentral.com/as...ml#post6334792
    10-25-2018 09:44 AM
  1. Stopwatch and Timer ticking noise - how to mute it?
    Last Post: 07-28-2019, 07:10 PM
  2. Pixel to pixel data transfer - or fresh start?
    By KillerQ in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-07-2018, 06:37 AM
  3. I have forgotten my private mode pattern. how can i reset the pattern
    Last Post: 10-21-2018, 05:45 PM
  4. lost si9m replacement not reading it
    Last Post: 10-21-2018, 03:01 PM
  5. Replies: 1
    Last Post: 10-21-2018, 02:39 PM
