    Somehow I broke the glass that covers my front camera. Is there a way to fix it or am I going to have to get a new phone because the camera still works but will not focus. Thanks!
    10-21-2018 10:16 PM
  2. Mooncatt's Avatar
    Can it be fixed? Most likely yes. What it takes to fix it depends on the phone. If you are skilled enough, it's possible you could even do it yourself.
    If you would create a free account here, could you please reply to this thread and let us know which phone you have? That way someone familiar with it may be able to give you a more direct answer.
    10-21-2018 11:28 PM
  1. Replies: 1
    Last Post: 10-22-2018, 12:49 PM
  2. How to stop sending read reports
    Last Post: 10-22-2018, 12:11 PM
  3. Replies: 1
    Last Post: 10-22-2018, 12:01 PM
  4. My text messages have disappeared and I can’t seem to make any calls.
    Last Post: 10-21-2018, 08:20 PM
  5. Need help Removing Ultimat Guitar Installer Icon On My Pixel 2, Cannot Remove
    Last Post: 10-21-2018, 07:32 PM
