    When I look at the Battery percentages I get device idle at 24%, cell standby at 20%, Android OS at 16% and Android system at 15%. Google play services at 13%. I cannot remove any of these. The battery drains quickly during the day as well and it's always the operating systems. Nobody seems to be able to fix this. Any suggestions? Thank you.
    10-26-2018 08:38 AM
  2. ManiacJoe's Avatar
    At a quick glance, this part
    suggests to me that your home has relatively bad cel signal strength so that the phone needs to keep the radios at high power to find a tower.
    Which phone?
    Which version of android?
    Which carrier?
    What are your normal signal strengths?
    Do you have the option of using wifi-calling?
    10-26-2018 10:38 PM
  1. How is Huawei in terms of OS updates and bloatware?
    By Snappy Phoenix in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 08-05-2020, 04:48 AM
  2. Hi. My name is Carrie and I have an addiction....
    By Carrie Greicar in forum Samsung Galaxy Note 9
    Last Post: 10-30-2018, 11:41 AM
  3. Why are there cached ads in my gallery (oneplus 6). Any thing to help?
    Last Post: 10-26-2018, 01:32 PM
  4. Is it possible to upload my website to google play?
    By Omanxp 45 in forum Ask a Question
    Last Post: 10-26-2018, 04:56 AM
  5. How to turn off visualization of pressed keys?
    Last Post: 10-26-2018, 04:14 AM
