    So...
    My kid spilled glue on my phone i cleaned it but some of it entered in my phone speakers my phone is Xiaomi redmi note 5 and now 12 hours have passed and my speaker quality isnt as before the sound is lower and the quality is not as before can you reccomend me a fix?
    10-26-2018 08:58 AM
  2. Kodak2's Avatar
    Take it to a repair shop. Any liquid that has entered the phone needs removing ASAP before any more damage is done.
    10-26-2018 12:10 PM
  3. waron97's Avatar
    I know this is kind of an old thread, but in case someone with the same problem stumbles upon it, here's what totally nailed it for me (using a redmi note 5 plus). With 2 speaker ports on each half of the bottom part, i took my vacuum cleaner, removed the head in order to just have the tube (which in my case is reasonably small). Covered almost all of the opening of the tube with my hand, leaving just a gap for the phone, which I then put in, and a couple of minutes for each speaker worked the magic for me. So that's how I managed to solve the problem. Don't know if it sucked 100% of the water out, but the quality of the sound seems to have been restored to normal. Hope this helps, stranger from the future!
    belodion likes this.
    02-04-2019 04:17 AM
  1. Hi. My name is Carrie and I have an addiction....
    By Carrie Greicar in forum Samsung Galaxy Note 9
    Last Post: 10-30-2018, 11:41 AM
  2. My battery is draining 50 to 60% overnight.
    Last Post: 10-26-2018, 10:38 PM
  3. Can someone please help me understand Photos?
    Last Post: 10-26-2018, 12:19 PM
  4. Why doesn't Samsung have the Strava app supported in smartwatches?
    Last Post: 10-26-2018, 08:35 AM
  5. Motorola moto g6 version phone
    By Lhumberjr2730 in forum Ask a Question
    Last Post: 10-26-2018, 07:30 AM
