    I noticed recently that my phone the s6edge and my work phone the s8 has begun suffering severe battery issues, 3 hours on standby mode has drained 50% of battery. And sometimes when in the pocket the phones get really hot. Both phones are updated to the latest software. Any solutions?
    10-29-2018 04:54 AM
  2. Kodak2's Avatar
    It could be an app causing the battery drain. Have you recently installed the same new app on both phones?
    To reply, please sign up to Android central.
    10-29-2018 05:13 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! See if the battery drain also occurs in Safe Mode: https://support.t-mobile.com/docs/DOC-34283. The steps should be the same for your S6 edge.
    10-29-2018 09:34 AM
  4. Rukbat's Avatar
    Also review your battery use - if you usually drain the battery almost to 0%, that alone would be the cause, and they both need new batteries. Lithium batteries can't be treated like that - 40% is about the charge or turn off" point. (50% is better, but 20% is getting into the "supporting battery companies" area.)
    10-29-2018 12:50 PM
  1. Transport ondrive foto to micro sd memory card
    Last Post: 10-29-2018, 06:59 AM
  2. How to turn off text to speech output on my motorolls m
    By Android Central Question in forum Moto M
    Last Post: 10-29-2018, 06:52 AM
  3. How to enable the native "RECORD CALL" button?
    By Ashim Bajimaya in forum General Help and How To
    Last Post: 10-29-2018, 04:53 AM
