LG K20 plus volume and camera won't work
JJWyatt72
I have a LG K20 plus phone just bought in April & the volume up & down buttons don't work at all & just now the camera will only take a front facing picture not on the back with the flash. What can I do to fix this? I have uninstalled all the apps in safe mode and did a factory reset and nothing.. Please help!!
Welcome to Android Central! If the problem persists in Safe Mode, then it's probably a hardware defect. If you bought the phone from your carrier, check with them first to see if they'll replace it. Otherwise, contact LG for warranty repair/replacement.
Bitterbuthappy
