    I hit the microphone to use my voice type and it tells me to enable something and I can't find it can you help me.
    11-01-2018 09:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What does it tell you to enable? Is it telling you to grant permission to the Microphone?
    11-01-2018 11:01 AM
  3. traebramlett's Avatar
    Yes it asks me to enable something.
    11-01-2018 11:29 AM
  4. B. Diddy's Avatar
    Right, but my question was what does it tell you to enable? Can you try again and tell us exactly what it asks you to do?
    11-01-2018 11:49 AM
  5. traebramlett's Avatar
    It says go to the settings and grant the permission to use this feature.
    11-01-2018 03:19 PM
  6. B. Diddy's Avatar
    Try going to Settings>Apps, select your keyboard app, and then Permissions, and make sure Microphone permission is turned on.
    11-01-2018 05:39 PM
  7. traebramlett's Avatar
    Finally got it to work.
    11-02-2018 10:46 PM
  8. B. Diddy's Avatar
    Great! What did you do to make it work?
    11-03-2018 12:26 AM
  9. traebramlett's Avatar
    Something wasn't turned on
    11-03-2018 01:09 PM
  1. Replies: 12
    Last Post: 02-23-2019, 12:33 PM
  2. Will an LG G5 from Sprint work on Straight talk?
    Last Post: 11-01-2018, 10:11 PM
  3. Why does my phone act up when I put in earbuds?
    Last Post: 11-01-2018, 11:39 AM
  4. How do I fix my power button?
    Last Post: 11-01-2018, 09:09 AM
  5. Replies: 1
    Last Post: 11-01-2018, 08:53 AM
