    i have a redmi note 4 running on noughat version. i have enabled pin and fingerprint. and usually i use my fingerprint to unlock it. But when it is restarted, it requires pin for the first time. And i really don't remember my pin. Also WIFI and Data Connection is off. And i can't pull down the notification bar too. How do i unlock it now? I CANNOT FACTORY RESET AS IT WILL DELETE ALL THE DATA.
    PLEASE HELP
    11-03-2018 03:07 AM
  2. methodman89's Avatar
    That is a security feature that you enabled. If you can't remember it, you'll need to reset the phone.
    11-03-2018 06:56 AM
  1. How to use dual app in umidigi Z2 pro???
    Last Post: 11-03-2018, 07:59 PM
  2. How do I permanently delete photos from my pixel
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 11-03-2018, 07:49 PM
  3. How can I recover data from my broken Pixel 1?
    Last Post: 11-03-2018, 01:39 PM
  4. how can i get my samsung galaxy s 5 phone to work
    By Android Central Question in forum Samsung Galaxy S5
    Last Post: 11-03-2018, 12:24 PM
