    Hi I'm curious, if I'm using a Xiaomi Mi Pad 4, and it offers a type-c connector, if I plug in a hub, and then plug in a mouse using typeA, the tablet screen will pop up a cursor eventhough I'm using a android OS or will it not function?
    11-03-2018 05:06 AM
  2. methodman89's Avatar
    A type C connector refers to the new standard as to size. The cable you select is the answer. Some are for power, data, or both, and will have ratings for speed and or volts and watts through. What cable do you have?
    11-03-2018 06:01 AM
  3. Rukbat's Avatar
    Short answer - if the hum has a type C connector, yes. If it has a microUSB connector, you can't plug it in.
    11-03-2018 11:38 AM
  1. why my HUAWEI P20 LITE auto screan trotation is not working at all?
    Last Post: 11-03-2018, 07:44 PM
  2. Lose keyboard and a pen sound on my note 9
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 11-03-2018, 02:25 PM
  3. how can i update android 4.1.2 to android 5 of docomo xperia z 10.1 tablet
    Last Post: 11-03-2018, 01:27 PM
  4. Contact pictures not settled properly in android pie
    By Android Central Question in forum OnePlus 6 & 6T
    Last Post: 11-03-2018, 12:36 PM
  5. how can i get my samsung galaxy s 5 phone to work
    By Android Central Question in forum Samsung Galaxy S5
    Last Post: 11-03-2018, 12:24 PM
