    100% to o% in minutes and some times turn off at 80% and say the battery is dead then i plug it in when its of and it will say i have 56% battery before i turn it back on if I turn it on plugged in it will turn on if not it showed a battery with exclamation
    11-04-2018 02:14 AM
  2. belodion's Avatar
    Perhaps the battery is bad.
    11-04-2018 05:50 AM
  1. 6T battery life
    By natehartey12 in forum OnePlus 6 & 6T
    Last Post: 03-28-2019, 09:44 PM
  2. Why do i have items in my history that i did not search?
    Last Post: 11-04-2018, 08:10 AM
  3. Why can't I lock the watch face
    Last Post: 11-04-2018, 05:55 AM
  4. High Def Vetsion of My Fav Nexus Wall
    By eric0668 in forum Wallpapers, Ringtones, and Themes
    Last Post: 11-04-2018, 01:42 AM
  5. How do I tfr files from S8+ to usb flash drive connected via an OTG adapter?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 11-04-2018, 12:06 AM
