    I would order a car phone holder but it has an ability to charge phones wirelessly. My phone does not support wireless charge, so does that car holder damage my phone (even through magnetic field or anything else?)
    I'd like to buy that holder if it does no harm to my current phone since I would likely to replace my phone in the future to one that supports wireless charging.
    So may I use this as a holder for now or it could do damage to my current phone?
    Thanks!
    11-10-2018 04:09 PM
  2. chanchan05's Avatar
    If you don't plug the holder in, I don't see why that would be a problem. There's no current to the charger anyway.
    11-10-2018 06:12 PM
  3. Rukbat's Avatar
    Even if you did plug it in, it wouldn't do anything to the phone - there's no wireless receiver in it.
    11-10-2018 10:06 PM
  4. Tobin Bell's Avatar
    Thank you for the replies!
    The car phone holder / wireless charger is also a magnetic holder, does that fact change anything in the result?
    11-18-2018 02:14 AM
  5. Kodak2's Avatar
    You will have no problems using your chosen phone mount, the wireless charging function / magnetic mount will not effect your phone. No need to power the holder but if you did it wouldn't matter.
    11-18-2018 04:33 AM
  6. Tobin Bell's Avatar
    thank you guys!
    11-20-2018 01:22 PM
  1. Why do I have a random alarm set for 7:09am every next morning?
    Last Post: 04-04-2019, 07:35 AM
  2. Does any ones phone go grey when changing a tab
    Last Post: 11-10-2018, 11:46 AM
  3. How did my update mess up my phone?
    Last Post: 11-10-2018, 11:08 AM
  4. HELP! Cracked glass on phone forcing me contemplate options
    By migdsb in forum General Help and How To
    Last Post: 11-10-2018, 10:04 AM
  5. My phone ringer doesn't ring lound rough
    Last Post: 11-10-2018, 08:41 AM
