    My phone as of recently is freezing up and shutting down I was hoping it might be a battery issue since my phone heats up quickly and battery been draining faster. Usually when it shuts off either a white light or blinking light show and for a bit either stays on samsung galaxy screen and after a bit after restarting boots correctly.
    I called this one repair shop and said the issue likely is a hardware or motherboard issue and likely have to scrap the phone. If it is the case what's my options of salvaging my information on there?
    And also is there a good chance this could be a battery problem?
    11-13-2018 03:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It does sound like it could be a battery issue, but it's hard to say without having a technician look at it. Does the problem also happen in Safe Mode? https://forums.androidcentral.com/e?...token=JlKUcJFb
    11-14-2018 11:59 AM
  3. Rukbat's Avatar
    If you can get it to stay operational long enough, you can copy files from it to a PC to salvage some of the information. If not, there's nothing you can save except what's already backed up.
    11-14-2018 12:03 PM
  1. Why is my samsung s6 sending the same text message twice?
    Last Post: 11-17-2018, 01:00 AM
  2. Are your Gmail notifications delayed on the Pixel 3 or 3 XL?
    By Stoopstroop in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 11-16-2018, 06:29 AM
  3. Why does my keyboard type number or symbol instead of the actual letter?
    Last Post: 11-14-2018, 12:07 PM
  4. Why is my battery skipping percentages?
    Last Post: 11-13-2018, 02:49 PM
  5. why cant I register to 4545 or 808 of TNT
    Last Post: 11-13-2018, 07:57 AM
