    phone turned off at night and is completely drained in morning
    11-18-2018 07:43 PM
  2. belodion's Avatar
    What do your battery usage stats indicate after such a drain?
    11-19-2018 05:56 AM
  3. Rukbat's Avatar
    Samsung S4 or LG G4? There's no Samsung S4.
    If it's the S4, the battery is about 5.5 years old - long past time for a replacement. Even the replacements, sitting on the shelf all this time, are probably pretty well shot.
    11-19-2018 02:46 PM
  4. belodion's Avatar
    ^ I guessed G for Galaxy, but even so there's no G4, and we ought not to have to guess unless the questioner simply cannot identify their device for some reason. To me, with limited knowledge of Samsungs, that could be S4 or Note 4, but it's not a good idea to rely on members' guesses and limited knowledge, unless there is no alternative.
    11-19-2018 04:17 PM
  1. Replies: 2
    Last Post: 11-20-2018, 02:11 PM
  2. Can I Disable dragging apps to disable them (LG X Venture)
    Last Post: 11-20-2018, 01:33 PM
  3. samsung galazy scanner at register walmart pay did not work
    Last Post: 11-19-2018, 04:18 PM
  4. Replies: 0
    Last Post: 11-18-2018, 07:35 PM
  5. why is it when i send a text back to someone it does it 2 times
    Last Post: 11-18-2018, 07:33 PM
