Originally Posted by
Android Central Question I tried wiggling the charger around in the port a bit and it kept starting and stopping to charge for some reason.
The reason is that one of the charging pins on the port is no longer soldered, so as you wiggle the cable, you move that pin and it makes contact, breaks contact, etc. (The hold is just a bit larger than the pin, and if the pin is sitting dead center in the hole wiggling the port moves the pin to the edge f the hole.)
The fix is to get the port replaced (they don't do "resolder the pins" jobs any more).
(The reason the Raspberry Pi charger only charged at 480mA is because the sense pin isn't properly connected (Pi doesn't use it) to tell the phone that this is an AC charger, not the USB port on a computer - from which it draws only 480mA, since a USB 2.0 port is rated at 500mA max.)
The fact that the current keeps falling off like that, though, says that the battery is bad too.
So, as Mooncatt said, if it's not a fairly new phone, it may not pay to replace the port and the battery. Get a price, then make your decision.
